oil leak
Oct
Hi
my friends 968 is leaking oil as per the pic can anyone identify the cause?
There is a gasket and O ring where the variocam connector comes through the cover, change those and its likely to be OK.
Remove the connector undo the cap heads and the ovalish alloy plate will pull off with a twist and you will see them.
Rich
