Oil leaks
- Thread starter kevin
Elliot Davies
Taken from a well know book.
kevin
I reckon that would be Adrian Streathers book, about £35 or so depending upon where you buy it. Pretty good resource if you intend to buy, as well as those of us who own a 964.
My oil leak is just weap though, not a problem I've been told.
Well it dosen't leave any oil on the garage floor.........
kevin
I would suggest this isn`t the case and it`s quite possible to have oil leaks on a later engine (as indeed it is on a 993 model 911 engine).
To put the whole thing into perspective when and if oil leaks occur it would have been prudent to have been planning a top end overhaul anyway to address likely wear in piston rings, valve guides, timing chains, tensioner ramps etc.
A 3.2 carrera engine for instance whilst unlikely to be leaking oil (on account of metal barrel base gaskets), is still going to be in need of some spanner lovin` to the metal bits once it`s done some work.
Keep smiling - Henry. PCGB member and Bright Orange race car register secretary !!
kevin
IMHO this top end overhaul business is vastly oversung, as you would say in your sales pitch, condition is king (or similar) I've seen engines with astronomical mileages on them, they weap a touch, but are in generally fine fettle. If a piece of equip has been well maintained it should last for yonks, given this how does one tell when repairs are due? Who in their right mind would accept being told to do leakdown/compression tests every year or so, just to find out when work is likely to be required?
Question, is this a self fulfilling prophecy designed to keep people in work I wonder?
Kevin.
Still no drips on the garage floor with his undertray removed.......
