Oil Level Check
- Thread starter Hales
It should be the case that from cold, on the first time you turn the key in the ignition .. but not start the car, that the oil measurement occurs in about 3 secs.
I always do that check when I first get in the car and before I drive off.
Enjoy your C4S .. it looks just like mine !
Phil T
996 C4S 2004, Silver, Black Leather
James Beaumont
richardjjs1
AS other say check ITS ON LEVEL GROUND and then carry out the test. Max 10 seconds if its not been running.
If its the standard 911 you can also use the dip stick
Peter Haslam
