Folks you may have seen my post a couiple of weeks back (Oil tank) trailing my plan to replace the gasket between tank and sender unit.
All went well, though in process the female earth connector came adrift and so I had to replace. Easy enough, and joy, no oil leak!
BUT, gauge needle now hits full stop as soon as igniton is switched on. I suspect that the new connection needs remaking, but another thought hit me; has the sender been reinstalled in the right place? On mine the earth connector is now at about 4.00 and the live connector at 6.00. Maybe they should be at 3.00 and 5.00 respectively? If it is wrong I guess that might mean the float is always at top position so explaining the reading.
Would anyone like to have a look and see where their connectors are compared to mine?
