Have just joined the 993 family with a 1996 Carrera Coupe in Arena Red with 65K and full history, having recently sold my 964.
My local OPC offered a free check over and they changed the belts for me at the same time as they were all looking a little ragged round the edges. On collecting the car, I was advised they'd drained some oil off because they felt it was too full.
However, following a decent 40 mile run and letting the car idle for 5 mins, the cabin gauge wouldn't rise above the "twenty past" level and the dipstick showed halfway between min and max. Even letting the car idle for another 10 mins made no difference.
On querying this with the OPC, I received the following emailed response:
"Driving the car will never allow the oil temperature to rise to the point for measuring, due to the cooling affect by moving through the air. Also, 5 mins is not long enough at idle, we leave them for at least 35 - 45 mins and the OSF wing to be so hot that it is uncomfortable to touch. We are quite happy with the level we have set it to and tend not to use the dipstick as it's not that accurate because of the temperature that has to be hot"
As a result of this answer I'm at a loss to know how you would expect to check the oil level. I tend to use the cabin gauge as a rough guide only, using the dipstick when idling after a decent run.
I'm not a newcomer to Porsche ownership but find the OPC response strange.
Before I reply to them, I would welcome any thoughts.
Regards and thanks in advance
Chris
Chris
