DaveyB
I have just had the third service on my 52 plate 996 Targa. The first was at a Porsche Main Dealer, and the other two were specialists in Peterborough and Bedford respectively.
Each time after I have had service, the on-dash display when doing the oil level test has read over maxiumum. I have then checked the dip-stick and this too has shown above maxiumum level. Each time I have had to drain out 1 litre of oil.
Two times on the way back from a service, I have pressed on a bit, and generated a huge cloud of oil smoke. I am sure this is the exccess oil being sucked into the engine.
Why would three garages make the same "mistake" each time. I thought modern garages had dispensers that you just typed in the quantity you want and it outputs that amount? Could my car have an unusual oil system? Anybody else had a similar experience?
