jw911forum
Hi,
Has anyone had this situation before? Essentially my oil light flickers (not all the time) once its warmed up and on idle tick over. I recently changed the oil to Castrol magnetec 10w-40w. It never did this prior to the oil change. I have read in the owners manual that this is normal and that it can flicker. When I blip the throttle etc it goes off and also when you are driving. Oil pressure is just over 4 when cold and just under 4 once warm. Car runs fine and ticks over etc all ok.
Any ideas anyone or is this normal? Should I have used different oil?
James
James
