The oil lost that I suffered came from the welded boss of the drainplug which in time can weaken due to the plug removal during oil changes
It was only a pin prick but enough to cause problems I filled it with high temp oil and fuel resistant silicone bond putty and voila
Be aware when you remove the drain plug that you don't put any stress on the boss as a new tank is £500
Paul
Paul
