p27549
For info i have just removed my cheap chinese headers and re fitted my standard headers back. To do this i had to remove the flexi oil line which connects the thermostat to the crank case . Access to the thermostat is very tight and this pipe is behind the oil tank return line. My oil tank line was original and would not budge so i decided to cut the flexi hose so i could use a 36mm socket to undo the B nut from the thermostat housing. To install the new OEM pipe and tighten was pretty difficult. I found a spanner from Halfords which did the job perfectly. Its a 36mm / 32 mm Viscos Fan spanner made by Laser
Just have an oil change to do and its back on the road with HEAT.
Happy new year to all.
