I had an interesting moment on the M3 on Friday.
I was driving along at normal cruising speed, when on the OBC display I had a picture of an oil can appear with the text "Indicator faulty".
The guage had been working fine, but then after a couple of secs dropped to zero, then went back up to 5.
I was trying to make up my mind whether this meant there was an elertical issue with the sender, so that the guage was wrong, or whether I might actually have an oil pressue issue (=panic!).
There were no red lights on the display, which I thought was a good thing.
When I stopped (about 3 mins later), I checked the oil level, which confirmed what I thought and it all seemed OK. There is a separate warning if the oil level measurement is faulty and it does not use the same guage, so I guess it is still reliable.
There was a check warning on the OBC, but after stopping and starting the car, this disappeared.
The only difference I can see is that the pressure gauge points to 2 at tickover and reaches 5 before 3000rpm, so it is over-reading.
It still runs OK.
I'll see if someone will look at it on Monday. Maybe there is a loose wire, or the sensor has failed.
It still runs OK.
