Chaps,
I changed the cylinder head on S2 a while back. The replacement was fully rebuilt and it all works very nicely as a result; a chunk quieter, I'm sure there are a few more horses in the mid-range and I'm very happy.
However the oil pressure warning light has taken to coming on very slightly since the work. It happens when the engine is hot and the car is in traffic and idling (i.e. lowest pressure conditions), and when the light comes on it does so very gently - only a slight glow. The slightest tickle of the throttle is enough to make it go out, and the pressure gauge doesn't drop below about 1bar. (For reference, the manual says "An occasional brief flickering of the oil pressure warning light at idle speed and normal engine temperature is no cause for concern if the light goes out upon acceleration.")
I'm not worried about engine damage from low oil pressure but am curious as to why this has started happening, particularly as I don't think the oil pressure has actually dropped since the work; I clearly recall looking at the oil pressure gauge one very hot day in traffic a couple of years ago and seeing it at 0.5bar, and the light wasn't on. Now, with slightly higher pressure, the light is coming on. Hence my question; how does the oil pressure monitoring and warning system work? Are the gauge and light driven from the same sensor or from different sensors? I know that the fat cylindrical Oil Pressure Sensor that plugs in by the power steering pump has two terminals on it, one for the gauge and one for the light, but are there any other oil pressure sensors on the car that could have failed? Or any other explanation for this slightly odd behaviour?
Thanks,
Thanks,
