hi , my car is bouncing off the 5 end stop of the druck press when driving normally , the oil level is only just at the min level would this be normal ?
should i put more in ? I was concerned over the pressure already ? also are there any factors that could cause high pressure apart from faulty guage?
she is blowing a good cloud out the exhaust after stopping then starting again
front moutned oil cooler fitted recently does this effect the indicated levels on the dipstick at all ie is the indicated range still valid even thou i have increased the capcacity of the system ???[8|]
thanks
Johnny
thanks
Johnny
