Further to my problem....!
There appears to be 3 'Oil Sensors' on a 3.2. The One to the right of the fan, which is cylindrical/round, and one lower down, and to the left, both easily seen.
I have just purchased the 'third' one which I think is the one which I think works the oil Pressure gauge, part no= 911 606 230 00. This I have eventually found at right of center, at the back of the engine after removing the large rubber hose between what I think is on the fuel inlet manifold, this is going to be a lot more tricky to remove.
However, I have, on all three run the test of removing the live wire terminal. This makes no difference at all to the problem, which, to clarify, when switching on ignition, before engine starts, the oil pressure gauge needle leaps up to max and stays there without moving.
When I switch off, the needle stays at max for about 9 seconds, before dropping like a stone.
Fortunatly I am sure the engine oil pressure is good as I have done lots of mileage without prob's.
