Hi there, I need some technical help for my Dec.88 3.2 It is regarding my oil pressure gauge, here is the info: 1/ oil pressure warning light works fine 2/ oil level gauge works perfect (new one fitted 2 months ago) 3/ oil temperature ok as well 4/ all the terminals have been cleaned Questions: 1/ is my problem the oil pressure sensor in engine 2/ is my problem the actual oil pressure gauge on dashboard (goes to 5 when you start the engine and stays there, goes to 0 when you stop engine; if I take the the connection of the actual oil pressure sensor same thing i.e. 5 when you start and 0 when you stop, in both cases stays at the top with no movement at all) Any help would be appreciated, thnaks. Salvador
OIL PRESSURE
- Thread starter salva
