OIL PRESSURE.....
- Thread starter Booman
adamtsobek
I own a 3.2 with 110K on the clock. The oil pressure is about 3.5 when running hot and at 3000revs. At tick-over, when hot it is about 1.8/2.0. When cold the pressure ges as high as 4.0.
Hope this helps
Adam
The oil preassure should be at least 1 bar when warm at tickover and at least 3-4 bar when cold. At high revs under load it must be at least 4 bar. A good reminder is that the oil preassure should read at least around 1 bar for each 1000 rpm.
