Are oil leaks from the left hand side of the oil pump common?
Does any body know if you can remove the oil pump without dropping the oil pan?
I'm trying to work out if an oil leak has been coming from the O-ring around the
lower balance shaft casing or the left hand edge of the oil pump.
TIA
Paul
TIA
Paul
