oil sender switch replacement
- Thread starter K_Claire
The pressure sender is (I believe) a VW part, and is underneath the engine (mine has a slight oil leak on it, as I spotted at MOT time, but not bad enough for me to sweat over.) It has two contacts - one of which drives the oil pressure warning light (i.e. the ouput is 'High' or 'Low'), the other of which drives the oil pressure gauge (i.e. has a linear output). If the gauge is reading normally but the oil pressure light is misbehaving, it could be that the sender is half-duff (IYSWIM).
Either way, check the output from the gauge with an AVO meter before replacing it, if you can.
Indi9xx
When was the belts last changed and by who?
What does your oil pressure guage read when the light is on?
If your 944 is a post 87 model, is it the light at the bottom of the oil pressure guage that comes on, or is it the oil level indicator on the left hand side of the instrument cluster that comes on?
The 964 has a button in the centre console to cancel the big warning light - shame the 944 didn't get the same.
Now that is interesting Fen - thanks for that post. I knew there was an oil level sensor somewhere, but didn't know where it was (other than in the sump, somewhere - doh!) or how it worked. If it works on a float system, that will explain why mine comes on when the sump is still 2/3 full - I expect that the float doesn't float as well now as it would have done when new, giving a slightly pessimistic view on the oil level.ORIGINAL: Fen
As Jon alludes there is a low level light (in oval dash cars) that is triggered by a float in the sump - they commonly fail. The other light is low pressure and is the bottom of the gauge, triggered as described above by Oli (I assume - never had an issue with that myself). Both will also light the large red warning lamp and for the level sender it will remain lit until ignition off regardless of subsequent change in the level or response of the sender if it is a bit dicky. In other words I believe the sender is read only at startup for oil level, probably to prevent the light flashing on and off during enthusisatic cornering.
I did also guess that it only took a reading when the ignition was turned on, as I have had an experience where the level light is off when I start the car, drive it briskly for a while, stop, turn the ignition off and on again within 5 minutes and the oil level light comes on. However, when the car is stopped again and left with the ignition off overnight, the oil level light doesn't come on when the car is started again the following morning despite there being no new oil added. This is presumably because the oil has now settled again in the sump, rather than being spread around the engine.
The symptoms are that when starting, the light comes on as normal and then doesn't go out unless stop engine. If afterwards you start the car again, the light behaves normally and switches off after starting and remains off.
The light only comes on about 10% of starts approx. Oil pressure reads 5 bars-so pressure good. Dip stick reads oil level halfway between max and min.
The belts have been changed at 48,000 as per handbook and car has now done 80,000 but that was about 10 years ago. (Do you suggest I need to change belts now anyway irrespective of oil light).
It goes off when going uphill....
sawood12
