Oil temp gauge
- Thread starter Lasitha
I can't tell you why, but it was never available, not even as an option. The OBC won't display it either. Apart from an expensive retrofit, if you just want to monitor it occasionally, I can only suggest getting a cheap OBD2 hand scanner, and plugging it into the diagnostic connector.
Its important to know the oil temp as it matters more than the water temp (which heats up much quicker) for when you can safely razz the engine.
I'd rather have an oil temp gauge than the pointless battery monitor thing.
My bro's Skyline tells you the temperature of the engine oil, gearbox oil, exhaust, water, turbo, as well as injector pressure, boost etc. Now THAT's what I call engine diagnostics...
Tool Pants
non Club member but v. knowledgable
The 997 also has a heat exchanger. When the 997 came out I wondered why the volt meter gauge was replaced by an oil temp gauge. I do have a theory.
On the older Boxsters you could push 2 buttons on the a/c display to see the oil temp.
