Hi folks,
I am looking for some advice on oil temperatures for my 85 carrera cabrio. During normal driving the temperature stays above the first white line. (Describing the gauge as having a white block at the bottom, two white lines in between and a red block on top). The pipes to the front cooler are hot so I presume the thermostat in the wheel arch is working. Sitting in traffic however the temperatue will nearly reach the top white line after 10 minutes of standing still.( There are some minor oil leaks but when the temp increases these get worse resulting in smoke from the engine bay. I have never noticed the temperature increasing like this in my previous 911's. Oil pressure is V good. I presume the temp should stay on or near the first white line under these conditions ?. Can anyone advise ?
John
John
