Went out for my first drive of 2006 yesterday having done quite a bit of work to her over the winter, everything appears great but for some reason I decided to check the external oil thermostat (Porsche list it as a regulator) which is housed in the rear wing behind the drivers seat, the pipes from here to the front of the car were cold, does this suggest a problem with the regulator?
I had been out for approx 20 mins to half an hour, would this be long enough for the regulator to allow the oil supply to be sent to the front oil cooler?
If it is not working will it do any damage for the short term whilst I am using it for short trips?
Do you have to buy a new regulator/thermostat or can you refurbish the internals of it?
Any help always appreciated.
Cheers guys
Cheers guys
