Chaps,
My S2 has always used a bit of oil. It's been an annoyance but I've lived with it. I know it leaks a little from the area underneath the oil filter/oil pressure regulator/oil pressure sensor but I've never got to the bottom of precisely which bit is leaking. I changed the cylinder head recently and thought that that may solve the problem but it hasn't.
However I have done some more careful investigations into how much is used and when. And I have found that the use is not at all consistent. I've used the car a lot recently and discovered the following;
- Long weekend away in Norfolk, approx 550 miles driven over 4 days, mostly two long journeys (there and back) but some short journeys while where. All driven fairly gently (wife in car). No oil use at all. (Yay!)
- Long weekend away to Spa and back. Approx 650 miles driven over 4 days, mostly two long journeys and only one short journey done while there. Driven hard and one long journey was on a notably hot day. Oil use = approx 300ml.
- Two days away to Nottingham and back. Approx 400 miles over 2 days, mostly two long journeys. Driven gently, mainly in the rain with the wife in the car. Oil use = approx 400ml.
I know I need to do some more detailed investigation underneath the car to find the source of the leak but does this inconsistent use suggest anything to anyone? A simple leak I would expect to leak at a constant rate (i.e. 100ml every x number of miles); this is not so. The car doesn't smell of oil and the plugs are clean, not fouled, so I doubt it's burning it. All oil measurements done to a common datum (parked on the same slope, measured to the top of the 'full' mark on the dipstick, with the engine cold.)
All suggestions (and suggestions of common leak points) very welcome, thanks.
