Paul Fraser
Need some help with my 01/86 oval dash 944.
On the right hand guage, oil pressure/voltmeter, do the oil-can and battery symbols light up when the ignition is first switched on. If not where are the low oil level and low voltage warning lights please (are these the lights at the bottom of the scales?)
I've just replaced my oil pressure sender as I expected the oil-can icon to light up and it hadn't been, but nothing changed (wish I had known this before trying: it took me over two hours and I eventually had to disconnect the oil filter, distributor cap and the engine manifold radiator pipe to get poor access to it, grrrrr).
