I have a 944s 16v the car has done 158k miles but had a full rebuild 10k ago including new rings, the other day I started the car and the "engine oil" red light stays on along with the large red exclamation light, this tells me there is little oil BUT the oil pressure is at 5bar running and 3bar tick over, the oil on the dip stick reads 3/4 full? Is it a sender fault? If so where is the sender situated so I can change it thanks, engine runs smooth no noises or tapping thanks
Oil warning light on!!
- Thread starter Lance
944 man
ORIGINAL: Lance
Its a level alert, rather than a fault warning. When the light comes on as it should the car will only need a top up.
Theyre particularly sensitive too, so parking facing slightly uphill will frequently be enough to activate it when you restart.
