Oil weight
A 40 will be fine. I use 5w40 and have had no probs at all. I think the quality of the oil is far more important than if you use a 40 or 50 as our cars will run fine on both.
I chose 5w as I wanted good cold start protection. It's been running so well on 5w I have considered dropping down to 0w. As the vast majority of engine wear actually only occurs in the first 5 to 10 mins while your engine is warming up and oil is getting to temp then it stands to reason cold protection is an important feature.
