OIL !!!
- Thread starter guychris
sawood12
xenon
ORIGINAL: sawood12
I run 5w40 with no leaks and minimal consumption (unless on a track day) so our engines are capable of running thinner oils. I guess it's a case of suck it and see and whatever works for you, peoples choices and experiences are wide and varied. I personally want to run the thinnest oil I can get away with to provide optimal protection, especially cold start protection as my car is my daily runner.
Me too. 5w40 fully synthetic.
ORIGINAL: John Sims
Mobil1 15w/50
Don't use 0w/40 it is too light for our older engines and will find its way through potential seal gaps and cause leaks.
Since I got the turbo, I have been using 5/30 or 5/40 for top-ups, it appears to use quite a lot, but I'm guessing thats either because a) I have an oil leak (think that is highly probable), b) viscosity is too thin or c) turbos use oil?. I'm going to go back to 15/40 or 15/50 at the next oil change.
Dave K.
