Oil?
- Thread starter gazzy
Steve Brookes
Moderator
You will have very low oil pressure when the engine heats up if you did use it ...and that will kill the main bearing etc etc .
Mobil 1 Motorsport is what I use ..not cheap ! but neither is running a Porsche ....
mcgc0
Apart from the benefits of this, I had this understanding that for high mileage engines using a high detergent oil will 'clean out' some of the build up of carbon deposits etc. The -ve of this being that any micro-meter play (or tolerance) between moving parts previously 'cushioned' or filled with the build up of carbon deposits, is 're-revealed' (if you know what I mean). The result being a slightly noisier engine and more free movement between those worn parts.
New/rebuilt/low-mileage engines then a no-brainer. Years ago I used to rebuild engines for all sorts and believe it or not we could run a rebuilt (petrol) engine on diesel oil, and often did. So long as you started with this and carried on using then fine. The benefit was a very high detergent oil preventing the build-up of carbon and oxidants. Mind you, if you switched to a mineral oil later you couldn't go back.
Maybe, and hopefully, oil technology has moved on considerably. I might call up Castrol or somebody and see if there is a fully synth oil recommended for high mileage engines (or of very low detergent content).
Marcus
mcgc0
Mobile 1 Motorsport though is fully-synth again but actually 15W-50, which is unusual, as nearly all/most fully-synth oils are around the 0W or 5W.
Mineral oils (or cheap engine oil!) = more frequent oil changes (sludge and anti-oxidant build up).
The question for me is more around finding the optimum performance balance for engine of 100k miles or more. If I find more I'll post..
Marcus
Mobil 1 Motorsport
Say no more..............
mcgc0
You go to somewhere like Opie oils and then look up oils that meet the Porsche A40 spec and you'll get 15 results (of which only two are semi-synth). The low cold point is 0w or 5w. The difference then is down to additives for different uses and qualities.
Me, I'm going to try the Mobil one below. And to answer your original question, maybe you are trying to be a a financially prudent person of the North [
Dekker
Mobile 1 Motorsport
Hi Melv, I wonder if you've changed your oil type since the engine failure last month?
David.
