David Green
I've got a 1999 C4 3.4, when I start the car in the morning the oil pressure is around 5 bar, as it warms up and is running at say 2k to 3k rpm it settles at around 3.5 bar.Once at normal operating temp at 2k the pressure is between 2 to 3 bar and only goes to 4 bar and marginally over once you get to 4k rpm. Even if you go past 5k rpm it doesn't go any higher. I've know someonme with a new C4S who says his pressure is regularlt around 5 bar regardless of temp.
I have owned 964, 911 including turbo and the pressure ahs always been around 4 bar once you get to 2k to 3k rpm.
Should I be concerned ?
