appletonn
As per a previous post, I noticed that I was missing a nut from one of the exhaust manifold studs earlier this week - unfortunately, I noticed at the same time that I was also missing part of the stud that it was once attached to....[8|]
So, in advance of a lengthy trip to Le Mans in June, and not wanting to inhale too many toxic fumes en route, should it start to blow, which it inevitably will at some point, once the gasket starts to disintegrate, I popped into see Jonny at Unit 11 this morning to see what my options were - desperately hoping that it might somehow be possible, through the powers of witchcraft (well, people are extracting 400hp+ from 3.2 944t engines through the same process...?!), to remove the stud in situ.
You can probably guess what is coming next...[&:]
Basically, either the engine would have to come out to be able to access the stud, or just the head off - just not accessible enough with everything in situ[8|]
So, do I...
1. Ignore it as it isn't blowing yet, and walk around going "tra la la la la" every time I open the bonnet, so as not to think about the missing nut/stud staring me in the face ....aaaarrrrggghhhhh?[
] OR
2. Get head removed, that one stud sorted and head put back as is with just new gasket set etc...[>:] OR
3. Whilst head is off, it would be daft not to get valves and valve seats recut along with guides if required and oil seals, along with head skim and replace all of the exhaust manifold studs whilst they are accessible...[
I know that I have probably answered my own question, but just wanted to share the pain[
Incidentally, the compressions checked by Hartech in december were 150psi on all 4 cylinders, so hopefull nothing too wrong with the pistons/bores/head?
Answers on a postcard no later than Thursday[
And yes Oli, I did hear that you don't get this issue with S2s.....[
So, do I...
