Lets say you had the following (hypothetically):
944 (250bhp) turbo engine in a million pieces, needs bearings, rings, gaskets, clutch and not much else to be complete (OK, a sump as well [8D])
The head and turbo have just been rebuilt so are effectively new, but standard.
You also have:
an Autothority MAF kit
TiAL wastegate (35mm IIRC)
full Hayward & Scott exhaust system
ECU map to suit the above running 1.01 bar boost (producing something over 300bhp)
Intended use of the car is purely as a toy for trackdays and mad Sunday runs. Making it a pig to drive in traffic is not an aim, but may be an acceptable side effect.
If you set your mind to it you can throw £300 - £500 a month at it and you want to build the best you can. You also want to be able to do some trackdays in it next year so ideally you want it to go together for a couple of grand in a way that you can improve over time without any major dismantling or having to do the same job twice (remapping excepted).
What would be on your shopping list, both during the inital build and then on the improvements list over time?
To get the ball rolling I'm thinking:
Stick with the 2.5 capacity
Work the crank (lighten?, crossdrill, knife-edge? suggestions?)
Balance the internals?
Rebuild with Raceware fasteners top and bottom
Use a Huntley Racing 'Full Metal Jacket with O-Rings' head gasket
Lighten the flywheel and use a Cup spec?, sintered?, other? clutch
Is it worth doing anything with the head?
Have I missed anything - given that I eventually want to see the 300bhp increase dramatically, based on this core engine?
Would it be worth starting out with a 3 litre block and crank and a 2.7 head, accepting 2-3 months longer in the build but ultimately having the, erm, ultimate spec?
What would you guys do?
You also have:
