smallspeed
Yesterday was going so well; woke up with a killer hang-over after just 3 pints the night before, it was raining, the cat had thrown up on the front room floor, and I was out of life-restoring diet coke.. Decided to go to a pub about 5 miles from home for a spot of lunch; I knew it would be quiet as the football was on mid afternoon so there wouldnt be many people in there until then..
I lead, my mate followed, and just as I turned into the pub carpark, it all went a bit "james bond" as I laid down an oil-slick Q would have been proud of!.. The amount of honking and flashing from my mates car I knew something was wrong (or he just saw a topless cheerleader squad's tour coach) so turned the car of instantly and rolled into a space on an upslope to make rolling out again easy. I got out of the car to see my precious lubricant deposit itself all over the carpark... This photo is from an hour later (it was raining heavilly all day) so you can imagine how bad it was at the time
First though was get a tow from my mate with him Volvo, but alas I couldn't find the towing eye, so scratched the towing idea despite his sugestion to "just tie the rope to one of the front suspension arms" [
] So, on the phone to the AA... The story unfolded thus;
14:00
Explained the situation; need towing, no towing eye, not enough clearance for an A-Frame, please send a flat bed. AA say someone will be there in an hour
15:30
Phone AA; where the hell are you?.. Computer system crashed at 2:30, lost all the jobs, however miraculously when they punched my membership number in all the details and the call where still there!.. someone will be with you within 45mins
15:50
AA guy turns up in a small van.. agree's can't be towed, and car is too low for an a-frame, so calls base and arranges a flat bed.. 1hr sir..
17:00
AA guy turns up in a tow truck with a fold out a-frame on the back, takes one look at the car and agree's with me its a no go, phones base and arranges a flat bed
17:45
rain stops for 1/2hr and the AA guy turns up with a flat bed, does a stirling job of loading and lashing the car taking a lot of care over the car, and drives me and the car at a sedate pace across leicester to my mates garage where I can take a proper look this evening
Got in at about 7:30 last night having gone out at 1 for some lunch, and still hung-over!!!
Right thats the rant bit over, time for the cry for help [
Im thinking because the oil poured out from the leading edge of the right rear wheel arch the problem is with the tubes/hoses from/to the oil tank to/from the engine, however because everything was covered in oil and it was lashing down with rain, I didnt really get much oportunity to investigate... Tonight Im going to strip that area out and take a proper look, however wondered if there's anything else I should add to the list of things to check at the same time? Also, if Im replacing the tubes or whatever it may be, and the oil, is there anything else I should do at the same time? Obviously the oil filters will get done, but not sure if there are some components in that area that might as well get replaced at the same time, or if there are parts that will likely need to be replaced (ie trim clips that may break, grommets that may be perished, etc).
Im quite glad this has happened when it did really, as it could have been so much worsel I dread to think what the result may have been had it happened at 80 in the outside lane of the motorway or something
Ben
14:00
15:30
15:50
17:00
17:45
Ben
