PRJ
Let the expense begin...
All has been fine with my Turbo until the other day when on the M23 in 4th gear the revs dropped suddenly and I appeared to be down to 3 cylinders. It cleared itself within a few seconds and all was fine until this morning. Fired her up from cold and it was only firing on 3 again.Wasn't stalling, but only just hanging on. Turned off and then fired up again, with the same problem. Left it for a couple of mins, so the immobiliser had kicked in again and fired up and all fine. Have just dropped my daughter at nursery and all was fine when I restarted and then suddenly in 4th gear, it's died again. Switched off and on a number of times (making sure immoboliser had engaged before trying each time) and still the same problem. Then all of a sudden I press the throttle and all 4 cyclinders are back. Ideas anyone?
