Onto front dampers, advice sought before I plough in - updated
- Thread starter blease
diabloam
I will prob see what the top mounts are like when I get the old struts off, but got a couple queries for all of you. First is it worth changing the top mounts since I'll have them off or if they seem ok should I just reuse them? Next my strut bolts are a bit crusty so where is best for getting replacements at a decent price, found one place but they seem to be after a fortune for just a bolt, albiet the top one is eccentric! any suggestions (also can you buy new track control arm castellated nuts)? I may just reuse the old ones but either way I am going to face the problem of alignment. Cause I stay in the sticks (Isle of Lewis, lol) I cant get four wheel alignment done here as there is a problem with the one garage that I thought could do it as the front and rear tracks are different widths which makes the machine they use throw a fit. I am changing the castor mounts for 968 ones at the same time so am basically going to be disturbing all the adjustable points on the front end. Question is, irrelevant of whether I reuse the old bolts or get new ones, can I get away with marking how they are on removal and then attemt to transfer these marks to the new struts, will I be able to get close? Or am I likely to be way out and make the car handle like a dog? Any suggestions as to how best I should tackle this.
Also with the rear struts, the bolt at bottom that goes into the alloy arm and also the top one that goes into a captive thread, are these known to be problem bolts to get out or should thay come out fairly easily with out damageing anything (i.e. shearing off or anything like that). Thanks for any pointers guys, appreciated as always
chrisg
FAB! Thanks - I need a new sig! (Although I hope you won't mind if I spell it correctly? [ORIGINAL: chrisg The Right Honerable Oliver.....
diabloam
Oct
diabloam
diabloam
chrisg
diabloam
diabloam
Fat Albert
Jonny944CS
Probably a bit late now, but if you car is an '86, it should have the short front alu wishbones (no hole in the middle). The correct top mounts for these are the cheaper £34 versions you mention. The same part as early 944 and all 924's. Porsche introduced the expensive/stiffer/complex 87-on jobbies to allow them to account for a 4° change in McPherson strut angle without having to change the mounting points on the inner wings - a consequence of the longer wishbones and various other parts introduced to accommodate ABS.Hm well concerning top mounts I did a wee spy on the internet (seen Iam at work, lol) and there is a couple of options. Promax do KLA solid ones for about £130 a pair but I reckon they might be quite harsh and more suitable for the track. Porscheshop weirdly list up to -87 year 924/944 ones for about £34 each but after 87- 944 (inc turbo) ones for a shocking £304, so you guys werent kidding about the price.
