Oops! Brake fluid leaking!
944Fripp
Currently fitting new front wheel bearings as well as a bit of housekeeping around the general area. I decided to fit anti vibration plates as the front brakes are very squeely. In doing so I used a brake piston spreader to make sure there was enough room either side of the disk. Whilst winding this in I suddenly heard dripping, looked under the car and....yep...brake fluid.
The top of the reservoir is soaking so it looks like that's the source and it's a clean up and bleed job when it's all done. I assume the same for the clutch too.
But am I likely to have done any damage though? Are the any seals I should consider replacing as a precautionary measure? Brakes are really not my area of knowledge but I have a vacuum bleeding kit and plenty of enthisiam so I guess I shoud be fine!!
My guess is that if any seals are damaged it won't bleed properly either.
Any ideas/views welcome!
Hope everyone is keeping well.
Should be fine, you just pushed more fluid back than there was room for in the tank on the master cylinder
As Waylander said - shoudnt be any problem.
I think we have all done this at some time (well maybe its just me :rolleyes:).
Just clean up thoroughly.
