OPC 24,000 service... details?
- Thread starter Guest
Major maintenance
Note!
- Not valid for USA!
- The engine oil and oil filter must be changed every 10,000 km (6,000 mls) on vehicles which are operated in countries with leaded fuel (country coding M 150 in the control unit)
- The term 'checking' includes all necessary subsequent work such as adjusting, readjusting, correcting and topping up, but does not include repairing, replacing and reconditioning parts or assemblies!
- The maintenance item> Replacing spark plugs < depends on the model year. Please observe the chapter "Additional maintenance"
- The maintenance item> Throttle actuation: Check smooth operation, check full throttle position with the Tester < omitted as of model year 2002.
Major maintenance after
40,000, 80,000, 120,000, 160,000 km etc./
24,000, 48,000, 72,000, 96,000 mis, etc.
- Diagnosis system: read out fault memory
- Polyrib belt: checking condition
- Changing the engine oil and oil filter
- Replacing spark plugs
- Vehicle underside and engine compartment: visual inspection for leaks (oils and fluids) and abrasion (lines and hoses)
- Coolant hoses: check condition; radiators and air inlets at front: visual inspection for external contamination and blockage;
- Coolant: check the level and antifreeze protection
- Air cleaner: replace filter element
- Particle filter: replace filter element
- Fuel system: visual inspection for damage, routing and secure fit of line connections
- Power steering: checking the fluid level
- Parking brake: checking the free play of the parking brake lever
- Brake system: visual inspection of the brake pads and brake discs for wear
- Brake hoses and lines: visual inspection for damage, routing and corrosion. checking the brake fluid level
- Clutch: play or pedal end position is to be checked
- Throttle actuation: check smooth operation, check the full throttle position with the Tester
- Steering gear: visual inspection of bellows for damage, check screw connections of running gear adjustment facility, front and rear, for secure fit
- Axle joints: check play, visual inspection of dust bellows for damage, check screw connections of running gear adjustment facility, front and rear, for secure fit
- Drive shafts: perform a visual inspection of the boots for leaks and damage
- Exhaust system: visual inspection for leaks and damage, check suspension
- Tires and spare wheel (collapsible wheel): checking condition and tyre pressure
- Check the door, lid locks and safety hooks of the front lid to ensure that they are secure and functioning properly
- Seat belts: check operation and condition
- Vehicle lighting: check function; all headlights: check adjustment; horn: check operation
- Windscreen wiper jwasher system, headlight washer: check fluid level and nozzle settings, pay attention to antifreeze protection in the winter months.
- Electrical equipment, warning and indicator lights: check operation
- Test drive: Remote control, front seats, foot and parking brakes (also actuation travel), engine, clutch, steering, transmission, ParkAssist, automatic speed control, TC/PSM switch, heating, air-conditioning system and instruments: Check operation.
- Oils, fluids: visual inspection for leaks
Long time no speak... how are you?
Thanks for replying... its coming close to that time of the year and OPC quote:
Major service
Every 24,000 miles or 2 years (up to and including Model Year 2003)
Every 24,000 miles or 4 years (from Model Year 2004)
FOR £538.00
So all that you mentioned above is included (inc plugs) in that quoted price for a 24K service?
Anyway, hope your well.
Chris
For a MY01 Additional Items are:
Spark Plug change at 48000 or 4 years
Airbag check and ancillary unit mounts after 4, 8 and 10 years, and then every 2 years
Brake fluid change every 2 years
Fuel Filter change at 48000
Polyrib Belt change at 48000
Transmission oil change at 96000
Front diff oil change (C4) at 96000
Check Roll over protection system (Cab) every 2 years
Condition report for long life guarantee every 2 years
I assume you are charged for all these additional items.
Diesel130
Spark plugs are not included. They are £168. See http://opc.cmwinteractive.com/servicepricing911996.asp?opc=4 for full details and prices of the 'extras'.
Don't forget to ask for your PCGB discount though!
