Just had my windscreen replaced by my local OPC.
On collection I noticed that the seal at the bottom of the screen was not pressing against the glass as it had done previously - see picture taken this morning before the screen was removed.
I said I was unhappy with this so the car was returned to the workshop but after 30 minutes or so the car came back with no discernable improvement. I was then told that this not the "real screen seal", it was therefore nothing to worry about being quite normal after glass replacement and that all cars with new glass would be in the same condition. In short nothing can be done and not even fitting a new plastic moulding will help [
So my question is; am I being told the truth? Do all of you out there with replacement windscreens have poorly fitting seals at the base of the screen? If there is someone out there with a new screen an a well fitted seal please let me have a picture so I can use this in support of my argument to get the work rectified.
Finally, while driving home I noticed that the screen mounted rear view mirror was vibrating to such an extent that the illuminated variable speed limit signs on the motorway were almost unreadable. I presume it is the mirror to glass adhesive that is causing the problem but is it possible that it is the whole windscreen that is shaking [&:]?
