Is it me or is good old fashioned customer care / service a thing of the past ?
Let me explain, purchased a 06 997s from a OPC in December 08 with just shy of 28k on the clock. Had a myriad of faults with the vehicle from the off which included the registration plates being fitted at an angle (1/2" drop from one side to the other) and a slight leak from the rear main. The front plate was rectified by drilling more holes straight through the plinth and the front bumper and using self tappers ! that made six holes in the bumper !. I was told the oil leak wasn't significant.
To be fair following a change in management most of the jobs were put right barring a paint defect on the N/S door which I have been told by two OPC bodyshops is a factory fault.
It took the best side of twelve months to get things sorted and as a gesture of goodwill I was offered a discount on the 4yr service which I graciously accepted.
Now we were still waiting Porsche's decision on the paintwork when the car went for service just after Easter and bear in mind that since purchase I have done less than 3000 miles and the rear main was no worse.
So you guessed it the oil leak now can be done and Porsche will pay ! thats great but the problem I have with this is that now I'm asked to pay for a clutch (precaution) even though I have complained about a judder, and the slave cylinder and arm had to be replaced at my cost. If this was carried out when I mentioned it the slave cylinder would have been covered under warranty but maybe Porsche would not have paid for the rear main due to it being close to point of sale !!.
Also the N/S cooling fan was found to be seized, I noticed that on bringing the car back home the O/S fan cuts in all the time and I have never heard it before, I believe that they have carried out a modification on the car making the fans cut in more often and that the N/S fan has not just seized.
In total the bill would have come to over £2500 !!
I wrote a letter of complaint and have just received a reply which is very negative, it says that the rear main now fits the circa and that the modification was carried out before I took delivery of the car !!
Do I expect to much from a £42,000 vehicle ! or even from an OPC ?
Oh apparently Porsche are now favorable to having the paintwork repair but because I complained the OPC have refused to do the work !
Be honest is it me ?????
