Opened my glovebox for the 1st time.....
lali
.... And my stereo came out of the dash?...!
The door was quite firm to open and then the stereo just started coming out.
Anyone else had this really odd behaviour?
Seems a bit odd Lali. I know the cables and arial lead are all a bit tight in mine and they have to routed carefully but I would have thought that it was more likely to pull them out the back of the stereo than push it out. There's maybe a bit of a "see-saw" action going on as the glove box arms pull out of the dash?
I would take the head unit out and see if you can re-route them and if the doesn't work take the glove box out which will give you pleanty of room to adjust things.
Very common problem when fitting stereos in 993's, glove box gets jammed with the cables, it needs to done right to allow glove to open fully
