OPRV Sleeve
- Thread starter PhilKent
PSH
It's been a while since I did mine, is it a plain tube or does it have oil holes drilled/machined grooves? I just can't remember.
If you can't find a source I would take accurate measurements of ID, OD and length and then check what's available in the precision ground steel tube that's available.You may get lucky and find just what you need.
Kind regards
Pete
Waylander - I think you're thinking of the guide sleeve, item 944 101 181 01 which is still available.
I was after the tube that sits near it. There is no image in the pet catalogue and speaking with Porsche they couldn't help.
Weirdly, I also needed 928 101 195 03 which is a 'fitting bush' that one of the crank studs sits within, but what I seem to have got is the part I needed. I'll now have to make the fitting bush from another piece of stainless pipe...
Mark
Regards the slow oil pressure, I would think first port of call is the OPRV as it's the easiest, then it would be the check valve in the cylinder head, but I'm no expert, so this is not technical advice
scam75
Well-known member
marojojoem said:Thanks Phil, The problem I am trying to chase down is that the oil is draining down to the sump so when I restart after the car has been standing for a day or two there is a significant wait for the oil pressure to build up once the engine has started. After that its fine. Sorry to hijack the thread but I was hoping that changing the OPRV might do the job.
Mark
Again no expert but I believe some oil filters that fit (non OEM) allow the oil to drain away down after switch off. The proper filters have some kind of valve that prevents this. Maybe someone else can clarify.
Stuart
Waylander
the only real way is with a wet pipe type gauge, a T connection and plumb one in
the electronic sender may well be at fault and not anything else
the other issues might be a hairline crack in the pick up pipe or a worn oil pump (unlikely) or a leak where the locktite has failed between the oil pump and the face of the block
Agreed I'm just relying on the gauge to tell me this but the top end does suddenly go quiet when the gauge registers the pressure so I think it is a real lack of oil rather than anything else. Once its there the pressure is consistent and good so I've ruled out cracks in the pick up or leaks, Im convinced the system is draining down into the sump when the cars standing.
Mark
Waylander said:How do you know the oil pressure is slow to build, don’t rely on the dash for that information
