DavidL
I won't hijack Oliver's thread I'll start afresh.
I changed my slave last year and all was well.
Recently I noticed that once a journey, usually when manoevering, the pedal would saty down. Otherwise it seemed fine.
Since I didn't do the master and pipe I thought this needs doing.
Anyway I couldn't see any fluid on the pedal and there is no fluid loss from the reservoir. So I bled it again and the same still happens.
Its odd as the pedal is really bouncy again after I've bled it but it will still stay down occasionally.
I'm assuming I should change the master and pipe anyway but might there be another reason? Some sort of return spring or something?
