Do these go the whole length of the drop glass as mine seem to stop about 1/2" short on both sides?
Can someone post a pic up of theirs please.
Ta muchly![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Ta muchly
chrishak said:You've discovered the third guaranteed failure on the Carrera 3.2, shrinking drop-glass scrapers. I also thought it was correct when I bought my car as they all had the same gap - until I saw a freshly restored car on which they fitted snugly.
Yours need replacing, they are reasonably priced from your OPC (or were 6 years ago) and it's a 30 minute job total.
chrishak said:1) Dip / main beam switch failure (indicator stalk).
2) Graunching noise at steering wheel - dry contact rubbing on horn ring in steering column
Actually, there's another;
3) Steering column top bush breaking up
Sage words from the man who stripped his car for repaint only to find he had an almost entirely rust-free bodyshell - even the cynics (mainly me) were astonished by the condition of the body, all the more remarkable as it is his daily driver, used in all conditions. An endoscope proved that the fine condition of the 'shell wasn't only skin-deep.911 targa said:Don't forget the o/s/f wing rust trap where the oil cooler pipes rise ,keep the muck clear and you should be ok
Paul
I'm guessing you were supplied Targa scrapers - and your car is a coupe..?kevinkjse said:Hi Kevin
When I replaced mine the new one's were too long and had to be cut down at an angle both ends
kev
Blimey, someone got out of the wrong side of the bed today..!911 targa said:Not an ice cub in hell just enjoy the car and expect it to get worse
Paul
Paul
