Grateful for any help with these faults, and on how to remove the oval dash instruments if that is needed.
First problem is, after several months of only occassional use, the instrument lights that illuminate the dials do not come on.
Second problem is that sometimes all instruments drop to either zero or nearly zero. This can happen at any time, and correct itself at any time. At first, it was clearly triggered by application of the brake pedal, and most worryingly, when these instruments are at zero, the brake lights do not come on.
So... probably a loose connection somewhere? Or could a voltage regulator have an intermittent fault? Any ideas on the most likely problem areas? I suspect that to remedy the lack of instrument lighting will require removal of the instrument panel. Does this require removal of the steering wheel and column cowl or can it be wriggled free after removing the visible 5 screws?
Frustrating to be spending this sunny weekend getting this sorted rather than out enjoying the car, but lack of brake lights at times would be silly.
Many thanks,
Ben
Many thanks,
Ben
