A ponderance here for your reflection:-
This is really for thems of us as whats removed our cycling valves, or are running modified chips with overboost protection removed.
On smurfing the Demon Tweeks site I came apon an adjustable overboost fuel cut off switch. IIRC it was IRO £100. This bit of kit was a bolt on to an electronic boost control system but it occurs to me that, linked to a relay, it could be used on its own to cut the fuel pump feed on a 951. Your thoughts.
About this product
Allows boost pressure to be increased over factory fuel cut/shutdown levels on modern computer controlled engines. Available in 2 versions - pneumatic or electronic. The pneumatic version is suitable for most cars using a map sensor to determine fuel cut level and should be used in conjunction with a Turbosmart boost control valve. The electronic version allows easier, more accurate settings to be achieved via the easy to read LED display. The compact water resistant case makes it ideal for under bonnet mounting. For use with a Turbosmart boost control valve.
About this product
