sidicks
I understand that the RME records the number of incidents of the car being 'over revved', classifying them as:
Range 1: 7300-7500rpm
Range 2: 7500-7700
Range 3: 7700-7900
Range 4: 7900-8400
Range 5: 8400-9500
Range 6: 9500-11000
Clearly range 1 and range 2 incidents would not be exceptional and range 3 would not be totally unexpected, but ranges 4, 5 and 6 would be unexpected and a potential cause for concern.
Does anyone know what would constitute 'abnormal' and hence require further investigation before the OPC would approve a warranty extension?
This happened to me recently, my 34,000 mile 997 C4S was referred to Porsche GB due to abnormal readings which required further investigation (at my expense) before the warranty could be granted.
I want to understand if it was the range 3 records that caused the problem (27) or the range 4 and 5 readings (1 in each).
Clearly basic physics mean that it would be impossible for the engine to only have 1 ignition in range 4 before it hit range 5, and similarly it would have to hit range 4 on the way down again - clearly therefore the range 4 and 5 readings must be an error.
Any information gratefully received!
I believe that the extra investigation instigated at the request of Porsche GB was unnecessary and hence I should have the fee (circa £100) refunded.
thanks
Sidicks
Range 2: 7500-7700
Range 3: 7700-7900
Range 4: 7900-8400
Range 5: 8400-9500
Range 6: 9500-11000
thanks
Sidicks
