we bought an 1986 944lux with an know overheating problem, apon looking at it serviceing history its had 2 raidator's and about 6 thermostats.
ok so far we have flushed the raidator, check pipes and rails, - the water seems to be free to go full circle around the engine, heater, and raidator with out no problem, - altho we cant get the heater to give out any heat any more, - the engine overheats with in about 30-40 mins of running on idle, the fan kicks in only once the engine has cut out once, but the raidator is not hot.
we have filled and blead the system from vaiouse point on the engine to see if its blocked etc, and apon checking the thermostat, we found there was not on installed - an possible fix from an old attemt to fix the problem before the pervious owner got the car. the only thing we can see that is rong is the water is too presherized a) from the bleed screw, b) from the filler cap on the expand tank. so we are thinking that it might be an blown headgaskit. the water is not oily when it comes out nor is oil messy it looks clean, (the oil filler cap has some white spots on it but we put this down to normal condersation etc) and we have hurd that the HG can go an not send oil into the water/water into the oil etc. so i ask is there anythink else we can do to fix this problem before going to replace the HG and is it possible not have the head skimmed, as all our enginerring contacts have gone
??? so is there anythink else we can try to fix the problem??
Oliver Rawlings
Oliver Rawlings
