P.A.S.M.
- Thread starter daro911
ORIGINAL: deadloss
And turning the question the other way around; I didn't specify PASM and don't regret that decision.
Regards,
Sean.
Snap [
ORIGINAL: daro911
ORIGINAL: deadloss
Regards,
Sean.
Snap []
Double snap.
Seemed like a great idea at the time to spec it, but ultimately the only winner is my dentist as it shakes my fillings out over the roads around here!![
Great if you're a track day hero - not so handy in the real world, sadly.
For those of you who did not spec it - regard yourselves as wiser than I and take a nice holiday with the cash in your pocket![
Rob
I would like to see maybe an in between setting.
ORIGINAL: Ente
I would still not spec it again as the standard suspension without PASM should be tougher than the PASM comfort setting and handle the twisties just fine. The only place I'd possibly miss the softie-PASM is when passing speedbumps
Fresh from having just done an hours test drive in a Cayman, fitted with PASM & Sport Chrono I can honestly say both these options (for my driving style) would not only be a complete waste of money but would ruin the excellent standard suspension and throttle set up the 987 S comes with.
Fortunately I was partly testing the car on a 12 mile fast cross country route I normally use for a fun blast in my Boxster and at no time did I feel a single advantage (from a personal point of view) over my standard set up. When in sport mode the ride was so jiggly and choppy Suzuki Vitara circa 1980's springs to mind [
Now to the sport chrono best summed up by saying "if it aint bust then don't try and fix it" [&o]
I've driven the mk2 Boxster S on 18"ers and non-PASM, on a couple of occasions and it is a very well controlled drive - based on that experience I would not spend my money on PASM.
I don't think P.A.S.M. raises and lowers the suspension - it just adjusts the damping etc of the shocks.
ORIGINAL: Dr OJ
I've specced P.A.S.M as part of the sports package because I wanted six gears, but can someone explain to me whether the suspension is permanently lowered 10mm or only when the sport mode is selected?[8|]
Permanently 10mm lower as I understand it. If you wanted 6 gears why not go for a more basic 3.2 in that case. Will the residual on a 2.7 with 6 cogs be much more than a standard spec car [&o]
For me, having five gears was definately out. My last three cars all had six gears and I know I would really miss having that extra gear. I think Porsche are well behind the times only offering five gears. In my opinion they only offer five to increase the spec gap between the 3.2s and the standard 2.7.
Would be nice to have gone for the 3.2, but I had a set budget and decided to go for a higher spec 2.7 instead.
