Johnny C
I was putting the car away before going on holiday, just locked it and the alarm went off, I think because I had the bonnet open to disconnect the battery. I reset it by opening the door with the key which worked, but it instantly locked itself again. I tried again, and the same happened. So I disconnected the battery and shut the bonnet and went off for 2 weeks.
I thought that by having the battery disconnected for 2 weeks it would reset everything.
I came back, opened the door with the key, reconnected the battery, shut the bonnet. locked with the key and tried pressing the fob to unlock. The alarm went off. So I unlocked with the key, the alarm went off but it locked the door instantly again.
I tried again, the same happened, door unlocked but then relocked.
Just on a whim I went to the passenger side and unlocked it, and it was fine. I tried the fob and it worked, the lights flashed a lot of a few seconds but since then it has been fine.
However I have had a couple of run ins with odd behaviour of the alarm (which goes off randomly every few days if the fuse for the inside lights blows)
I am hoping it's just some weird design idea that if the bonnet is open to potentially do some mischief when the car is locked, it decides that no-one is getting into the drivers side and unlocking via the passenger side resets it.
Any ideas?
Any ideas?
