I have a PA1000 which is not always very good at responding to being plipped and often takes several attempts for it to work. Once I was stuck by the side of the road for about 20 minutes before it decided to respond. Is there a solution?
Another point: I have two remotes, one is larger and has a red LED light and is the one that I normally use. I have a second smaller one that has the Porsche name on it and then below the buttons 'Security System'. This has not worked since I bought the car nearly 18 months ago, and which I attributed to a flat battery. I have replaced the battery and it still doesn't work. I got out the red master remote, which works, to see if the smaller remote needed to be reconnected having not been in use for a long time. Having made numerous attempts at a connection nothing happens. Again is there something I am missing? Is the smaller remote one that is normally used with the PA1000?
Any help would be appreciated.
NSM
