GordonT said:
I had this come up yesterday on the way home from an R3 run-out.
I know there are a couple of threads on this subject but I was keen to pick your collective brains. Jeff (Motörhead), you seem to know a bit about this. I do have a Porsche extended warranty which was on the car when I bought it. Should this be covered do you think? I haven’t spoken to the OPC yet.
Thanks!
Funnily enough I came out of the car park on the 2nd coffee stop and had a PSM failure...pulled in the lay-by 1/2 mile down road, turned off restarted and the fault cleared...is your fault still showing now...turning off and on again after clears up things Like this when some spirited driving has confused the car!
