Pads and discs
- Thread starter charles.y
I say they are rubbish for 2 reasosns - the bells rust in 5 minutes after fitting them and that looks awful, especially if you have Cup wheels. OK you can paint them but they aren't cheap enough to make that worthwhile against the others that don't need to be painted. More importantly they seem to warp slightly and cause vibration after a few thousand miles, even just in road use.
ORIGINAL: Fen
I had that exact problem when i fitted some zimermann to my merc. Utter rubbish.
appletonn
My solution was to paint the bells before fitting them on the '44 this time.
If you can get the Brembo or Sebro for the same price, then I would choose them over the Zimmerman for that reason alone
cdickinson
Will be therefore putting Brembo or Sebro on next...
Diver944
ORIGINAL: charles.y
Are the pads on the 951 (86 model) same as those on the S2s?
Yes
