Paint correction
Gordon Attar
Dear Experts
My 944T has obviously spent some time under a tree that deposited SAP/ birds droppings, I thought I would be able to take of with the clay bar or autoglym paint renovator, it hasnt worked on my test areas it has improved a bit, any suggestions!?
I suspect that there is a layer of resin or two that I need to get through first, any suggestions on how to remove.
I will can finish the car of with zymol or autoglym!
Gordon, I would imagine that any local valeter will have the same selection of chemical cleaners that I carry on my van for those exact reasons. The right cleaner will wipe it striaght off - don't let them overcharge you - it will be seconds [:)]
clay bar should get rid of the sap, how bad is the bird droppings, has it marked the lacquer, if it has it will have burned itself into it and will probably need some correction and new lacquer.
